1998 Ford F150 battery/alternator/voltage regulator
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHERFHARRYO
my check battery light has come on, my battert tests at 12.5 when engine is off, but when i start it the voltage goes done to 10 volts. I took the alternator to the shop to bench tested and they said it is fine. could it be the voltage regulator (the box on the fire wall)
Apr 13, 2008 at 5:25 AM
FLEXY5
  • 512 POSTS
I'm not sure which box you are refering to. Can you take a picture and post it. The main computer should be the voltage regulator. Post the picture and we'll go from there.
Apr 13, 2008 at 3:40 PM
