1998 Ford F-150 Air Flow Through Cooling Vents
CHIPS8
  • 1998 FORD F-150
  • V8
  • 160,000 MILES
Air flow through the cooling vents shuts off during acceleration, but it sounds like the blower is still running. As soon as the accelerator is released, air flow resumes. Does anyone have a suggestion as to what is going on?
Monday, August 24th, 2009 AT 4:26 PM
MJR346
  • 132 POSTS
Check the vacuum reservoir behind the battery for a unplugged vacuum line, a crack some wheres in it, or the check valve having a issue with it going to the a/c in the vehicle is most likely causes
Monday, August 24th, 2009 AT 9:28 PM
CHIPS8
Finally got a chance to check it out, and you'ree right on target. Found the line broken where it joins the tee. Thanks for input.
Tuesday, September 8th, 2009 AT 8:43 AM
