1998 Ford F150 4x4 problem
1998 FORD F-150
150,000 MILES • V8 • 4WD • AUTOMATIC
MBKBUCK
I have a 98 Ford F150 with the 4x4 shift on the fly (dash switch) when I engage the switch I get a couple clicks from dash area and the 4x4 light comes on but no engagement of 4x4. Same issue on both 4H and 4L. Have checked and changed 30A fuse under the hood and no result or change. Where do I go next.
Dec 3, 2008 at 11:12 AM
RDSSCHROCK
  • 11 POSTS
Have you gotten a solution to your problem yet? If so, would you share what the fix was?
Dec 9, 2008 at 7:20 AM
