1998 Ford F150 4 WHEEL DRIVE
16,500 MILES • V8 • 4WD • AUTOMATIC
MIKEBOCEK
I USED MY 4 WHEEL DRIVE ON A SATURDAY, WENT TO USE IT AGAIN ON MONDAY, NOTHING. SEEMS LIKE THERE IS NOTHING FROM THE SWITCH TO THE TRANSFER CASE. TESTED SWITCH, ALL FUSES, MODULES I COULD FIND, ALL GOOD. TOOK TRANSFER CASE OFF AND TRIED ON ANOTHER TRUCK, IT WORKS ON OTHER TRUCK, SAME WITH THE SWITCH. PUT BACK ON MY TRUCK, DOESN'T WORK. ANY IDEAS WHAT COULD BE WRONG?
Nov 13, 2009 at 1:48 PM
  • 110,246 POSTS
Are you getting power to the switch? Have you checked the wiring / plug to make sure there is no breaks in the wiring?
Nov 19, 2009 at 12:23 AM
MIKEBOCEK
found the problem, after 22 hrs of labor tracing every wire, turns out gem module no good. thanks anyway
Nov 21, 2009 at 6:53 AM
