1998 Ford F-150
CRZYSHOT6
  • 1998 FORD F-150
Electrical problem
1998 Ford F150 V8 Four Wheel Drive Automatic
I need help putting a new stereo in. I have the keys I just am not sure how to take the dash apart?
Thursday, October 29th, 2009 AT 5:18 PM
  • 109,755 POSTS
Actually, I believe the only thing that needs removed it the trim around the radio. If I remember correctly, it is either cliped in to place or Ford used velcro to hold the trim. Gently pry on the trim to see if it will come off. Be careful not to crack it.
Once the trim is off, there should be two screws holding the radio. Remove them, disconnect the wiring and antenna and the radio will pull out.
Friday, October 30th, 2009 AT 8:13 AM
