1998 Ford F150
1998 FORD F-150
TAVIA
how to replace the window wiper motor.
Jan 20, 2009 at 8:08 PM
KEVIN12881
  • 336 POSTS
raise hood, detatch neg. bat cable. 2 remove the left side windshield wiper arm and cowl grille. 3 remove wiper linkage assembly bolt and stud nut. detach the wiper link and unplug the electrical connecter. remove the moter assembly0to0chassis bolt, detach the moter from the bracket and lift the cowl opening. instructions may differ slightly, but once you are started it should be straight forward
Apr 3, 2021 at 7:01 PM
