1998 Ford F150
157,000 MILES • 6 CYL • 2WD • AUTOMATIC
LOCO1JM
I have a 98 F-150 and I'm having issues with my brakes. When braking the truck pulls to the left, not sure what it might be. Also when going at a slow speed and stepping on the brakes my rear right tire locks up, but only at slow speeds like 5-10 miles. Replaced both wheel cylinders and worked fine for a day and then started doing the samething again.
Feb 26, 2009 at 3:34 PM
2CARPRO JACK
  • 11,533 POSTS
As far as the rear locking up goes, have the drums been machined? shoes recently replaced? sometimes when less expensive shoes are used, the arc of the shoe is incorrect and too much material makes contact with the drum and can cause a locking up situation.Likewise if the drum has been machined and is too big in diameter the same thing can happen. Front end pull- are the pads wearing evenly side to side? alot of the time a brake pull is caused by an alignment issue or problem with the front end
Feb 26, 2009 at 11:36 PM
