4x4 actuator
1998 FORD F-150
CHUMLY3
My truck will not shift into 4x4? Automatic floor shift light does not come on only when starting truck up then goes out. Thanks
Dec 20, 2008 at 2:15 AM
BLACKOP555
  • 10,386 POSTS
This sounds like you have a transfer case encoder that has gone bad. Here is a diagram to help you get it changed out. Check out the diagrams (Below)
Apr 12, 2021 at 5:05 AM
CHUMLY3
Hey, that worked I replace the 4x4 actuator encoder and the truck works great, thanks 2Carpros :)
