Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Interior
Instrument Cluster
Not Working
1998 Ford F150
1998 FORD F-150
117,450 MILES • V8 • 2WD • AUTOMATIC
RHEALW
MEMBER
dash guages do not work including speedo and tach..changed sig.bulb and steam cleaned engine only..?????everything pluged in as before
Oct 13, 2008 at 12:22 PM
BLACKOP555
Experienced Mechanic
it all work till you change the flasher bulb and.
steam cleaned the engine???
Oct 13, 2008 at 2:14 PM
RHEALW
MEMBER
everything worked fine before engine clean and bulb replaced
Oct 14, 2008 at 12:29 PM
BLACKOP555
remove the bulb put the old one back in and check all fuses again.
the instrument still out?
make sure you ddint get any electricals wet or anything when vehicle was washed.
Oct 14, 2008 at 1:24 PM
RHEALW
MEMBER
will re-check all fuses tomorow and advise...thanks
Oct 14, 2008 at 1:37 PM
BLACKOP555
thanks, i will be waiting for your response.
Oct 15, 2008 at 9:45 AM
RHEALW
MEMBER
checked all fuses etc..still not working...took to ford dealer..will know tomorrow i hope..will advise
Oct 16, 2008 at 12:04 PM
BLACKOP555
keep me informed.
ask if you wanna know if their price and diagnostic sounds right.
Oct 17, 2008 at 8:51 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
