1998 Ford F-150
MOREGALAXY
  • 1998 FORD F-150
  • 6 CYL
  • 85,000 MILES
I went out to go to the store and I looked and saw that my front tires had a rust color all over the metal wheels, both sides, and nothing on the rear tires wheels. What could this be? Should I take it in?
Monday, May 31st, 2010 AT 12:26 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, when you say metal wheels I take you are talking about the Rims and that when you say both side you mean driver and passenger side. If so then a question or 2.
Were do you park you truck?
Do you have a Central Sprinkler System with a well (Ground Water) if so did you happen to park the vehicle were the sprinkler may have sprayed on the wheels? If so then the rust color on rims could be from that.
Monday, May 31st, 2010 AT 12:37 PM
