HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Tires
1993 Ford F-150 left front tire
SAMMIE123
MEMBER
1993 FORD F-150
V8
4WD
AUTOMATIC
200,000 MILES
Cant get the hub off
Wednesday, June 23rd, 2010 AT 2:36 PM
BLACKOP555
MECHANIC
Some have hubless rotors and some have hubbed.
If you have hubbed youll need a special spanner wrench to push in while loosening the axle nut.
If its hubbless then youll just need a simple socket and breaker bar.
Friday, June 25th, 2010 AT 12:12 PM
Please
login
or
register
to post a reply.
Related Tire Content
F350 Tire Blow Outs
I Have A 2000 F350 With 150000 Miles. The Privious Owner Must Have Been Hit In The Back End And Quarter Panel Because I Found Body Work....
Asked by
fchouinard
1935
FORD F-150
GUIDE
Tire Wear Problems
A vehicle tire wear pattern is subject to the condition of the suspension, air pressure, alignment, balance of the tire and the ability of the shocks or struts to hold the...
Tires
Which Tires Would Give Better Traction On An F-150 2wd In The Winter, Snow Tires Like "blizzak Tires" Or All Terrain Tires Like "firestone...
Asked by
glak150
2003
FORD F-150
2011 Ford F-150 Tires
Can My Truck That Originally Had P27565r18 Tires Use P26565r18 Tires Safely?
Asked by
jarreltff
2011
FORD F-150
Wheels And Tires For A Newbie
I Have A 2002 F-150 Xlt 4.2v6 4x2 With 255/70r16's. I Have Found Some Used 255/70r16's With Decent Tread Mounted On 1995 Ford Explorer (all...
Asked by
jefewhit
1 ANSWER
2002
FORD F-150
Screaching From Underneath
2001 Ford F-150 Squeaking Behind The Tires. Need New Shocks Or Just A Simple Lube Job?
Asked by
bme122
1 ANSWER
2001
FORD F-150
VIEW MORE
Tire Pressure Indicator Warning Light
Lower Control Arm Bushing Replacement
Tie Rod End Replacement
