1998 Ford F-150 speedometer
150,000 MILES • V8 • 4WD • MANUAL
SEAN080844
my speedometer wont work. the vss is good and the cluster is good. i havent checked the harnass on the vss or the harness on the cluster for voltage but if they both do have voltage what else could be the problem?
Nov 3, 2010 at 4:51 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Does the speedometer read inaccurately, bounce around or not work at all? It is very possible that the little gears on the transmission that run the VSS have been damaged and are no longer giving the info. to the sensor. With the sensor itself being good, instrument cluster good and assuming wiring is good, I would put my money on that being the issue. You will want to check fuses if there is no voltage somewhere though.
Nov 3, 2010 at 1:18 PM
