1997 Ford F150 will not get out of 4wd
1997 FORD F-150
118,000 MILES • V8 • 4WD • AUTOMATIC
ZASTROW21
the truck was put in 4wd to tow a car in the snow about a week ago whoever was driving parked the truck in 4wd and turned it off ever since then the ruck will not come out...it binds thru turns and does not go over 30mph and if it does it is running at 4500rpm and shakes.
Mar 11, 2010 at 3:25 PM
  • 110,244 POSTS
Do you have the electric shift 4wd or the shifter on the floor.
Mar 13, 2010 at 9:18 AM
ZASTROW21
i have the electronic 4wd switch in the cab
Mar 15, 2010 at 7:33 AM
  • 110,244 POSTS
Have you checked if the actuator on the transfer case is getting power?
Mar 15, 2010 at 2:23 PM
