1997 Ford F150 Using Oil
150,000 MILES • V8 • 4WD • AUTOMATIC
97F150
I have a 1997 Ford F150 with a 4.6liter V8. This past year I have noticed that my truck is using considerably more oil than it used to. Atleast two quarts every 1500 miles. There is NO smoke of any color and no leak that I am aware of.
Mar 8, 2009 at 11:10 AM
ZACKMAN
  • 4,202 POSTS
If there is no visible leak when it is parked, then it is leaking while you are driving (when the engine is pressurized), leaking through seals. Go over the engine bay from the top and from the bottom and try locate a "wet" area. Clean the are with a can of brake cleaner, wipe it clean. Drive the vehicle for a day or so, and re-check the engine bay. If you find wet area, then you know it is leaking through that area. Usual culprit is the front and rear main seal, or camshaft seal. (If it is leaking through the seal).
Mar 8, 2009 at 6:26 PM
