1997 Ford F150 transfer case
137,000 MILES • V8 • 4WD • AUTOMATIC
PJBROWN2
when i tried to put my truck in 4L it would not go and now i have no drive in any gears and when i try to put the truck in park it grinds really bad. and the truck will roll in any gear im thinking the transfer case in stuck in netural? can yaw help me out with this problem
Dec 4, 2009 at 1:29 PM
  • 110,246 POSTS
It sounds like you are correct. All of the symptoms sound like the transfercase is in neutral. The most likely problem is the actuator on the transfer case. Check to see if the actuator is getting power when you shift the transfer case.
Let me know what you find.
Dec 5, 2009 at 8:37 AM
