1997 Ford F150 Tire stuck
23,000 MILES • V8 • 4WD • AUTOMATIC
STILLWATER10
  • 27 POSTS
On my 1997 ford f-150 the right rear tire locks up going forward but not in reverse . it will stick as i drive forward then kick in i don't know if its the rear bearings or e-brake. and does this have anything to do with an abs light.
Nov 22, 2009 at 12:41 PM
  • 110,248 POSTS
Do you have rear drum or disc brakes? Honestly, it sounds like a sticking park brake. The park brake will work much better going forward and not be as noticeable in reverse.
Nov 22, 2009 at 12:49 PM
STILLWATER10
  • 27 POSTS
There drum brakes.
Nov 22, 2009 at 11:02 PM
  • 110,248 POSTS
Have you tried removing the drum? Chances are what you said is correct. If the park brake is stuck on, you will have trouble removing the drum.
Nov 22, 2009 at 11:14 PM
STILLWATER10
  • 27 POSTS
I removed the drum with out an issue and reassembled the brakes . there is gear lube leaking on the rear right from the seal but that side is not sticking
Nov 27, 2009 at 7:05 AM
  • 110,248 POSTS
The axle seal will need replaced. THe gear lube will cause that brake to grab. As far as the left side, if the drim came right off, were you able to turn the axle? If not, something has come apart in the differential or you have a seezed wheel bearing.
LEt me know.
JOe
Nov 27, 2009 at 9:11 AM
STILLWATER10
  • 27 POSTS
Now that i have reassembled the brake on the left rear side it no longer sticks the brake is a little sponge but the tire turns free. abs still comes on and the brake feels hard like i am on ice .
Nov 29, 2009 at 6:45 AM
