1997 Ford F150 tempature reading from computer
1997 FORD F-150
150,000 MILES • V8 • 2WD • AUTOMATIC
RODNEY B HILL
My F150 truck will at times shut down to about 30mph. I am told this is the computer thinking the veh is running hot. In fact it is not running hot and a ck of the system shows the sensor for the engine to the computer is reading over 300 degrees while resting and the engine is cool. I replaced the sensor and a new computer did not fix the problem. I removed the sensor from the engine and after 100 miles no problem. But I now have no way of knowing if my truck is running hot because the cluster on the dash is not working. Will this fix my problem and what is the downside to having removed the sensor to the computer. IE fuel flow matters relating to temp. changes
Sep 18, 2010 at 2:48 AM
  • 110,244 POSTS
If you are refering to the temperature sending unit, it won't hurt the engine. Based on the fact that it spikes when you connect the sensor, it sounds like there is a short in one of the wires. When you connect it, you are completing a circuit where there is a short.
Check the wiring for shorts.
Sep 21, 2010 at 3:39 PM
