1993 Ford F150 Replace PCM
151,000 MILES • V8 • 4WD • AUTOMATIC
BGOING2
How to replace PCM?
Jul 28, 2008 at 9:39 AM
BMRFIXIT
  • 19,053 POSTS
Its rarely fail
why are u replacing it ?
its located on left side firewall by the brake power booster
Jul 28, 2008 at 11:01 AM
BGOING2
My truck initially (sometimes not all the time) was starting really hard (once 10 – 15 minutes), once started had very little power, then would suddenly engage. Once up to speed it acted like one of it's tanks had run out of gas, bucking for a moment or two then running okay - though gas was fine. It would do this without warning at different speeds but generally at 55 - 60 mphs. Sometimes not at all. Took into a shop and we changed plugs, checked wires and changed out fuel filter. While test driving ran fine. Several days later, started bucking much more frequently, shifted from 1st to 2nd with a hard bang and would not shift to 3rd. In addition the engine check light would come on. Check light would go off and it would run fine for a few minutes then back to running rough and wanting to stall. When it did stall it restarted easily but would want to stall again. Took it to Ford dealership to have it tested but they reported they had done an upgrade on their computer equipment and were unable to analyze a 1993 motor. Took it to AAMCO, they checked it out and said I needed a new computer. Approx. $460 parts and labor. Called another Ford dealership and they said $560 but would try to give discount to get closer to AAMCO price. Very generous of them... not!
Jul 28, 2008 at 12:48 PM
BMRFIXIT
  • 19,053 POSTS
I think they are trying to take the easy way out
I don’t believe its the PCM
check with a local repair shop most of them still have the old scanners
to help u out
good luck
Jul 28, 2008 at 1:05 PM
BGOING2
What does it sound like to you?
Jul 28, 2008 at 1:09 PM
BMRFIXIT
  • 19,053 POSTS
check the EGR and its operation
Jul 28, 2008 at 1:19 PM
BGOING2
Sounds logical... When it is acting up I can also smell something different but can't quite put my finger on it. Similar to the smell you get when a new car hits the throttle hard when you are behind it...
Jul 28, 2008 at 1:30 PM
BMRFIXIT
  • 19,053 POSTS
disconnect the egr and give it a try
Jul 28, 2008 at 2:10 PM
