1997 Ford F150 Statring
207,000 MILES • 6 CYL • 2WD • AUTOMATIC
STEVE SCHUMAN
I am only able to get the truck to start by turning ignition on and putting transmission in neutral. Brake lights are not working but running lights are.
Sep 23, 2009 at 3:32 AM
JNOVACK
  • 723 POSTS
check you brake light switch under dash at brake peddle for brake lights and starting probblem in park also check neutral safty switch for starting probblem also check fuses for brake lights also have someone step on brake peddle and use volt ohm meter to check for voltage at plug
Sep 23, 2009 at 4:19 AM
