1997 Ford F150 Starter
151,000 MILES • V8 • 2WD • AUTOMATIC
MHSKID77
I just replaced my starter in my 1997 f-150. It has 151xxx miles on it. For some reason my engine keeps cutting out/ stalling on me wile i am idleing. What do we think the problem is?
Sep 13, 2009 at 3:53 AM
JDL
  • 16,098 POSTS
Welcome to the site. How long since a tune-up? If you have a digital multimeter, I'd take an inductive reading from the plug wires, engine idling. It's not a conclusive test, but as a first quick test, and you don't take anything loose, you don't penetrate the plug wire insulation and don't take the plug wire loose. Even one of the low end dmms will give an inductive reading, you just touch the dmm lead to the plug wire, ground the other lead. Say, most the readings show about 1/2 volt and one or two others show zero. I know where to start checking. There are other things that might cause that, like a vacuum leak or egr, something.
Sep 13, 2009 at 4:08 AM
