1997 Ford F150 scraping noises
114,000 MILES • 6 CYL • 4WD • AUTOMATIC
VANESSA80
I just bought this car yesterday and it drove perfectly with no problems. The car is lifted 19 inches off the ground and I don't know if the alignment is off or what but when I accelerate the floorboards make a scraping sound.Also the odometer is off by 10 miles. example while im going 65 the odometer reads 55.
Mar 22, 2010 at 1:53 PM
  • 110,248 POSTS
The only thing I can say about the noise is check under it to see if there is any evidence of something rubbing. Also, check the universal joints to make sure they are good. With that much of a lift, many things could cause it.
As far as the speedo, I'm going to guess you have huge tires on it. Think about it. The tires you now have take longer to make a complete revolution than the original size tires did. As a result, the speedo reads how fast the tires are spining and since they are bigger and take longer to make a complete turn, it appears to the vehicle that it is going slower than it is.
Mar 25, 2010 at 6:28 AM
