When i take off going slow 0-5 mph it is real rough. It bounces a lot when going that slow.
Jun 22, 2008 at 8:38 AM
BLACKOP555
✓Experienced Mechanic
check the tps sensor and the fuel filter, if you put the pedal down at a start to about halfway does it accerlate just fine? how about crusing at highway speeds does the problem only happen in the low accelerator pedal positions.
Jun 22, 2008 at 2:27 PM
HOSSY2010
MEMBER
[quote:cffb73fe35="blackop555"]check the tps sensor and the fuel filter, if you put the pedal down at a start to about halfway does it accerlate just fine? how about crusing at highway speeds does the problem only happen in the low accelerator pedal positions.[/quote:cffb73fe35]if i put it down half way it is fine. Also at highway speeds it is ok. it is only when i just give it a little gas
Jun 23, 2008 at 2:18 AM
BLACKOP555
check for TPS voltage with the pedal at closed throttle and then go steadly up in pressure, is it erratic in the begining and smoother after it gets past half throttle or stay the same throughout?
