1997 Ford F150 radio -lights
140,000 MILES • V8 • 4WD • AUTOMATIC
KENDAK
my truck has running lights sometimes & sometimes not ...I have checked fuses & switch but can't find anything...inside overhead lights do not work ..lights in door work...radio stays on when switch is in the off position...only way to stop radio is to manualy shut it off....bell dings even when key is out until door is shut....remote door lock won't work...but electric locks & windows will work from door switch ..all this stuff started overnight...am 59 yrs. young & have worked on my trucks all my life but can't figure this one out...thanks for any help...Kent
Jan 27, 2008 at 7:05 AM
MIKE H R
  • 3,094 POSTS
Kent, I am 60 and been playing around with cars since the 1960s, like a back yard mechanic. Did this all start at once? The are a couple of things I can think of , 1. check the body grounds , 2, the igniton switch could be bad, or 3, a crossed wire. Maybe one of the other moderators can add anything to this
Jan 27, 2008 at 12:40 PM
