1997 Ford F150 Power Booster?
214,000 MILES • V8 • 2WD • AUTOMATIC
DANG
My front brakes want to stay "engaged" as if I were lightly holding the brake pedal when I am not touching a thing. If the power booster is bad, how can I test it? I tried to depress the calipers with a large C clamp and could barely get them to move. It is unlikely that both calipers went bad at the same time. The pads are slightly more than half worn. Rotors are in descent shape. What do think my problem could be?
May 26, 2009 at 7:16 AM
MIKE H R
  • 3,094 POSTS
I don't think it is the power booster but could be the abs sytem or the master cylinder. I worked on a gmc that did the same thing and found that a valve in the abs system was not letting it bleed back and was keeping some pressure on the brakes. I would have it checked out. If you have to drive any distance they could get too hot and warp the rotors or burn out the brakes. You can try bleeding the brakes really good, maybe if something is hanging them up it might clear itself out when you bleed them. Just for infomation I had tried that and it worked for a little while then it would do it again. so keep careful eye on them .
Mar 10, 2021 at 4:47 AM
