1997 Ford F150 operating parameters
147,000 MILES • V8 • 4WD • AUTOMATIC
AEOLIANRANE
  • 16 POSTS
where can I find a list of engine operating parameters. I have an Actron cp9145 and in im readiness test it is showing my engine at 20% load at idle. Also abslt tps at 18.8. All may be good, but I don't anything to compare it to. The mass air unit is new.
Jan 11, 2009 at 4:47 AM
RACEFAN966
  • 5,029 POSTS
Do you have any codes? Are you having any problems with the running of your truck? Get back to me as then I can be of better help.
Jan 12, 2009 at 1:58 AM
AEOLIANRANE
  • 16 POSTS
po304(misfire #4). Installed new coils and wires. Missed one. Will fix and clear code.
Jan 12, 2009 at 11:14 PM
RACEFAN966
  • 5,029 POSTS
Ok let me know what you find after that. If you need anything else just ask. Thanks.
Jan 13, 2009 at 2:27 AM
AEOLIANRANE
  • 16 POSTS
cleared codes. MY anylizer is telling me that % of load at idle is between 18 and 23% is that correct?
Jan 13, 2009 at 3:09 AM
RACEFAN966
  • 5,029 POSTS
% of load from what?
Jan 14, 2009 at 1:49 AM
AEOLIANRANE
  • 16 POSTS
the engine. (answer to your question) Also my abslt tps% is 18.8%. is that correct. I have an engine anylizer. I can see what my os sensor short term correction is based on my % of load, they are operating correctly. All other vehichles that I tested, at idle their tps was at 0%. Mine tested ok. 1 volt to ground and 5 volts to 0 at wot koeo. Engine running at idle tps was at 18.8%.
Jan 19, 2009 at 11:21 AM
RACEFAN966
  • 5,029 POSTS
I don't use percentages I use voltage. So with the key on engine off the voltage on the reference wire should be .8 volts and should increase steadly to 4.5 to 5 volts with no glitches or drops. So if it does that then it is working right.
Jan 19, 2009 at 11:25 AM
AEOLIANRANE
  • 16 POSTS
it started out more than .8 and didn't go above 4.2 at wot. Purchased new tps but could't screws out. I think they are original, stuck real good. Have to use easy out in the am. I tested my mass air sensor and in voltage terms it tested ok. 1.4 volts at 2000 rpm in park in garage.(exhaust outside).
Jan 19, 2009 at 11:51 AM
RACEFAN966
  • 5,029 POSTS
Sounds like a tps problem as the voltage reading you give me. The screws are put in with thread locker so they will be hard to get out.
Jan 19, 2009 at 12:00 PM
