1997 Ford F150 OLD Caliper hanging up
1997 FORD F-150
74,658 MILES • 6 CYL • 2WD • AUTOMATIC
KEN1940
REPLACED CALIPERS WITH LOADED REBUILT FORD CALIPERS AND HAD ROTORS TURNED. AFTER DRIVING 10-15 MILES LF CALIPER LOCKS UP IT GETS EVEN WORSE IN REVERSE. IT EVEN GETS THE WHEEL HOT. THIS WAS THE REASON I REPLACED THE CALIPERS IN THE FIRST PLACE. WHEN FIRST INSTALLING CALIPERS IT WAS A TIGHT FIT TO GET IT OVER THE ROTOR.
Jun 5, 2010 at 4:09 PM
  • 110,244 POSTS
If you replaced the caliper and it is doing the same thing, Try this. Pump the brakes so the caliper sticks and you can't turn the wheel. If it doesn't release, open the bleeder valve to see if that releases the pressure. If it does, replace the rubber brake hose going to the caliper.
Let me know what you find.
Jun 5, 2010 at 4:19 PM
