1997 Ford F150 No air flow at floor
145,000 MILES • V8 • 4WD • AUTOMATIC
DDHLITITZPA
I'm unable to get heater air flow at the floor vents. The blower works in all speeds. I can select defrost only and panel only and get plenty of air where its supposed to be. When I select panel and floor combined I only get panel - nothing at the floor. When I select defrost and floor combined I only get defrost - nothing at the floor. When I select floor only I only get defrost. I'm able to change temperature from hot to cold - just can't get air out of the floor vents.
Sep 29, 2009 at 1:57 PM
BMRFIXIT
  • 19,053 POSTS
System and doors controlled by vacuum
check vacuum source from under the hood and into the firewall
Sep 29, 2009 at 2:37 PM
