1997 Ford F150 motor swap
19,000 MILES • V8 • 4WD • AUTOMATIC
DANIEL470
  • 14 POSTS
is there any special precausions to take while swapping out a 4.6l motor on a ford f-150??
Jan 6, 2009 at 7:42 AM
DAVE H
  • 13,383 POSTS
ENGINE
Removal (Expedition, F150 & F250)
Disconnect negative battery cable. Remove hood. Drain cooling system. Remove radiator. Discharge A/C system using approved refrigerant recovery/recycling equipment. Release fuel pressure and disconnect fuel lines. See FUEL PRESSURE RELEASE & FUEL LINE CONNECTIONS .
On Expedition, remove air conditioning condenser, EGR manifold tube and unclip mega fuse holders from junction block bracket. Disconnect starter relay cables.
On all models, remove upper intake manifold. See INTAKE MANIFOLD . Remove bulkhead connector cover. Disconnect necessary grounds and harness connectors. Disconnect necessary water and vacuum connections. Unbolt power steering bracket and position reservoir and bracket assembly aside. Remove ignition coils and brackets.
WARNING:The electrical power to air suspension system must be shut off prior to hoisting, jacking or towing an air suspension vehicle. Air suspension switch is located behind right kick panel area. Failure to do so can result in inflation or deflation of air springs, which may cause vehicle to shift during these operations.
Raise and support vehicle. Remove starter. Remove A/C compressor. Remove transmission cooler line from block mounted clip. Remove transmission inspection cover, torque converter bolts and transmission-to engine bolts. Remove power steering retaining bolts and position power steering pump aside.
Disconnect dual converter "Y" pipe from exhaust manifolds and position aside. Remove right and left engine mount bolts. Lower vehicle and support transmission. Remove engine from vehicle.
Jan 6, 2009 at 8:15 AM
