1997 Ford F150 Horn
195,000 MILES • V8 • 2WD • AUTOMATIC
RYMARZ
The horn on my Econoline 150 stopped working. I checked the fuse located in the engine compartment and it was OK. Any suggestions you might provide would be appreciated?
Nov 18, 2008 at 8:46 AM
BLACKOP555
  • 10,386 POSTS
disconnect the wiring harness at the horn and check to see if you are getting 12v+ when the horn button is pressed.
if not check the relay and the button.
if your getting 12v make sure the horn is grounded properly to a frame and that the horn is operational.
Nov 18, 2008 at 9:18 PM
