1997 Ford F150 Hesitation if i push the gas pedal a little
1997 FORD F-150
SSBSH21
Engine Performance problem
1997 Ford F150 6 cyl Two Wheel Drive Automatic
my truck acts like it wants to stall out if I push the gas pedal down just a little bit like when driving through a parking lot or in traffic or something. If i push it down far it runs fine, it seems like it is a very low rpm problem. Ive changed the fuel filter but that didnt do anything and I put some injector cleaner in it. Any Ideas?
Oct 24, 2009 at 9:41 AM
Check and test the MAF, TPS and the fuel pressure if okay test the Cam and Crank sensors and the Knock sensor.
Oct 24, 2009 at 10:11 AM
