1997 Ford F150 engine shakes
118,963 MILES • V8 • 4WD • AUTOMATIC
ROBERTHAMBLIN
P0202 is the code i was told from autozone salesman...He is unsure but says it is more than likely a bad injector?....I am at wits end? Any advice?
Aug 8, 2009 at 2:46 AM
BLACKOP555
  • 10,386 POSTS
chances are the fuel injector on cylinder 2 is bad. check the wiring harness for it first. as they are not as expensive as an injector.
when you replace the injector i would suggest doing all of them as that cylinder may or may not run richer then the rest.
Aug 11, 2009 at 3:10 AM
