1997 Ford F150 cv joints, hub and bearing assembly
1997 FORD F-150
141,000 MILES • V8 • 4WD • AUTOMATIC
AEOLIANRANE
  • 16 POSTS
my pass. side cv boot is wide open(needs replaced). I put new rotors, pads(both sides). Lower control arm and ball joint on driver side. Since then I have a hum that neither decreases or increases with vehicle speed. Also, the hum stops if I turn to the right and remains constant if I turn to the left.
May 26, 2008 at 10:32 AM
MERLIN2021
  • 17,250 POSTS
You'll find that the left front has the bearing problem, So it looks like both sides need work again...CV joint will click when enough grease is lost, and enough dirt packs into it.
May 26, 2008 at 10:38 AM
AEOLIANRANE
  • 16 POSTS
replaced hub and bearing, fixed the problem with the vibration, and in process of CV jont. Have purchased, will replace this week.
Thanks for all help!
Jun 1, 2008 at 11:39 PM
MERLIN2021
  • 17,250 POSTS
Your welcome.
Jun 2, 2008 at 10:36 AM
