Timing: chain and gears?
JMRW80
  • 1997 FORD F-150
Does a 1997 Ford F150 XLT 8Cyl 5.4L, have a timing belt, chain or gears?
Thursday, May 31st, 2012 AT 2:25 PM
DOCFIXIT
  • 18,828 POSTS
this engine has a timing chain to keep the camshafts lined up. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Cheers.
Thursday, May 31st, 2012 AT 2:27 PM
MILLSTON
  • 1997 FORD F-150
V8 four wheel drive automatic 150,000 miles.
Camshaft timing. Chilton's manual is showing a different diagram than how it was by almost 180 degrees. This is a Windsor 4.6. Do you have a diagram? Thanks
Monday, October 1st, 2018 AT 11:28 AM (Merged)
https://www.2carpros.com/forum/automotive_pictures/12900_46_timing_marks_1.jpg
PTANNEN
  • 1998 FORD F-150
  • V8
Does a 1998 Ford F-150, V-8 have a timing belt?
MIKE H R
  • 3,094 POSTS
Depending what engine you have a small engine 2.3 ro 2.5 engine has a timing belt and the bigger engines have a timing chain.
RANDALL HALE
  • 1995 FORD F-150
  • 4.9L
  • 6 CYL
  • MANUAL
  • 100,000 MILES
Replacement of gear on new after market can, does it get pressed on?
Saturday, September 19th, 2020 AT 1:53 PM (Merged)
  • 109,852 POSTS
Welcome to 2CarPros.
Yes it gets pressed on. There is a special too required to do it. Here is the part number:
Ford Camshaft Replacing Adapter T65L-6306-A
I attached a picture of what the tool looks like. Keep in mind, if you get this from a dealer, it will be expensive. However, most parts stores will have one to lend or rent.
Let me know if this helps,
PACHYAUTO63
  • 40 POSTS
  • 1993 FORD F-150
  • 4.9L
  • 6 CYL
  • MANUAL
  • 125,000 MILES
This vehicle does not have a belt or chain for timing. I need to know the positions to put the cam and crank sprocket pulleys.
  • 52,797 POSTS
Good afternoon.
This is part of the way back machine. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed. Picture attached below. Roy
