1997 Ford F150 brakes clicking
1997 FORD F-150
141,000 MILES • V8 • 4WD • AUTOMATIC
AEOLIANRANE
  • 16 POSTS
under normal braking everything is great. I replaced pads and rotors about 1000 miles ago. When under hard braking it seems like the trans will downshift, with an abnormal thud and the brakes will start clicking. They will continue clicking until I come to a stop or let up just a little on peddle pressure. If I let up on peddle pressure the clicking stops and I can again apply hard peddle pressure with no clicking.
Good luck. trans is aode, new cv joints, ball joints(lower), hubs and bearings.
Jun 4, 2008 at 11:08 PM
BLACKOP555
  • 10,386 POSTS
it could be that the brake mounting hardware is loose and when your stop hard it grabs faster and hits causing the thudding then the clicking.
check the brakes first.
Jun 5, 2008 at 2:39 AM
