1997 Ford F150 Brake Lights - & fuse panel
178,000 MILES • 6 CYL • 4WD • MANUAL
SWILKES
It was recently discovered that my brake lights are not coming on. Before I go to extremes and replace the bulbs, I was trying to figure out which fuse it might to check and see if that was the problem. The fuses all seem to be fine.
Is it just possible that all 3 of the bulbs went at the same time? Is there something else to check before I go ahead and replace the bulbs?
Thanks for your help and any suggestions you might have.
Scott[img:1e13e225e1]http://www.2carpros.com/forum/automotive_pictures/201573_100_3450_1.jpg[/img:1e13e225e1]
Jun 14, 2008 at 2:11 AM
CHOLA
Check the wires on the brake pedal switch,usually one breaks off...pretty common on these trucks
Jul 13, 2008 at 2:08 PM
