1997 Ford F150 anti-theft
TRACY742001
  • 6 POSTS
1997 Ford F150
my F-150 is a 5 speed I always shut down truck with clutch depressed and in 1st gear. I did that and the factory anti-theft alarm came on (horn blowing and lights flashing) I disconnected battery for 15 minutes and reconnected but alarm stays activated
May 9, 2008 at 12:20 AM
2CARPRO JACK
  • 11,533 POSTS
Will it shut off if you lock then unlock the drivers door? If not it will need to be scanned to find out which sensor/switch or other component has shorted
May 9, 2008 at 12:52 AM
