1997 Ford F150 Air blows only from the defrost setting
129,000 MILES • 6 CYL • 2WD • AUTOMATIC
KHOWARD73
Whether I am running the aircondition or heat, and no matter if I select max air, air condition, vent, defrost, etc the air only comes out of the defrost vent.
Jun 14, 2010 at 3:51 PM
  • 110,248 POSTS
In this case, you are looking for a vacuum leak. Check under the dash and the hood. If the engine is running, you may get lucky and hear a hissing from the leak.
Let me know what you find.
Jun 16, 2010 at 3:44 PM
