1997 Ford F150 air bag light
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
ARMAS
how to get rid of air bag light
Oct 30, 2009 at 12:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
you will need to use diagnostic scanner capable of scanning the SRS system to retrieve the SRS code(s) that is causing the airbag light to come on. You can then delete the code as well and the airbag light will go out, so long as you fix the issue.
Oct 30, 2009 at 12:55 PM
