HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Warning Lights
Airbag Light
1997 Ford F-150 air bag light
ARMAS
MEMBER
1997 FORD F-150
6 CYL
2WD
AUTOMATIC
200,000 MILES
How to get rid of air bag light
Friday, October 30th, 2009 AT 7:44 PM
BLUELIGHTNIN6
MECHANIC
You will need to use diagnostic scanner capable of scanning the SRS system to retrieve the SRS code(s) that is causing the airbag light to come on. You can then delete the code as well and the airbag light will go out, so long as you fix the issue.
Friday, October 30th, 2009 AT 7:55 PM
Please
login
or
register
to post a reply.
Related Airbag Light Content
1997 Ford F150 Transmission/speedometer/airbag Lite
My 1997 F-150 Has @86000 Miles And My Airbag Indicator Would Flash Now And Then And Then It Seemed To Stop. Well Today I Started Down The...
Asked by
murfbabe
1997
FORD F-150
VIDEO
How to Retrieve and Erase Airbag Codes
Instructional repair video
GUIDE
Airbag Warning Light
The Airbag Safety Warning Light is on because the self check portion of the airbag operating program has detected a problem and the system is now shut down including the...
1997 Ford F150 Lights
My Airbag Stays On Also My 4x4 Light On The Dash Stays On The Lights On The 4x4 Switch Wont Come Dont Know If Thats All Connected Mainly...
Asked by
shokypo
1 ANSWER
1997
FORD F-150
Airbag Warning Light Is Flashing
What's The Reason Behind The Airbag Warning Light Flashing 5 Times, Than 2 Times, Repeating This Sequence 5 Times Before Remaining...
Asked by
tagloff
1 ANSWER
6 IMAGES
1998
FORD F-150
1999 Ford F-150 Air Bag Light On - On The Dash
99 Ford F150 4x4 5.4 V8 Supercab 172000 Miles. The Air Bag Symbol Is On - On My Dash What Do I Need To Fix The Problem So The Air Bag Symbol...
Asked by
My99172F150
1 ANSWER
1999
FORD F-150
1994 Ford F150 Airbag Light
My Airbag Light Flashes 3 Times, Pauses And Then Flashes 2 More Times. What Is The Meaning Of This Code?
Asked by
tagoodwin
1994
FORD F-150
VIEW MORE
Oil Life Reset Ford Explorer 2011-Present
Oil Life Reset Ford
