1997 ford f150 4x4 4.2 liter automatic
1997 FORD F-150
HEMICUDA
Hello, My truck has about 192000 miles, ran good Until I had to Brake hard for a animal in the road! Now the PCM power fuse blows 30 amp? I Swapped relays still blows. And blows when key is turned on to run poistion!Wont blow with relay out! Tested power at F24 red wire good,F30 terminal good, fuse there also good! No water leaks at windshield!
Jun 29, 2007 at 12:45 PM
HEMICUDA
Hi, Wanted to get back with you about my truck and the pcm fuse blowing! We found the problem, It was the coil pack! replaced it and no problem. I guess hitting the brakes was a fluke or just bad timing. Thanks for your info tho, Great web site!
Jul 4, 2007 at 8:37 AM
