HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
Drain Plug
1997 Ford F-150
OSCAR1794
MEMBER
1997 FORD F-150
Engine Mechanical problem
1997 Ford F150 Two Wheel Drive Manual 130000 miles
anti-freeze come out of the engine oil drain plug.
Monday, July 7th, 2008 AT 6:24 PM
OBXAUTOMEDIC
MECHANIC
Indicates Blown Head Gasket.
SPONSORED LINKS
Monday, July 7th, 2008 AT 6:30 PM
Please
login
or
register
to post a reply.
Related Drain Plug Content
Timing: Chain And Gears?
Does A 1997 Ford F150 Xlt 8cyl 5.4l, Have A Timing Belt, Chain Or Gears?
Asked by
jmrw80
3 IMAGES
1997
FORD F-150
1997 Ford F150 Mass Air Flow
Backfires When Trying To Start. When Finaly Starts Idols Smooth But Backfires When You Give It Gas. Computer Says Its Mass Air Flow, Does...
Asked by
trevor d
1 ANSWER
1997
FORD F-150
1997 Ford F150 Oil Pump
Does My Windsor 4.6 Motor Have An Oil Pump? If I Keep The Speed At 50mph And Above It Runs Normal. If I Have To Run At A Slower Speed It...
Asked by
ardith ainslie
1 ANSWER
1997
FORD F-150
1997 Ford F150 Oil Filter
I Have Been Trying To Get Vthe Filter Off. The Filter Wrench Crusched The Filter. I Put 2 Drivers Thru It To Try To Turn It. No Go. Just...
Asked by
MARK WRIGHT
1 ANSWER
1997
FORD F-150
1997 Ford F150 Starter And Battery
My Truck Starter Tries To Engage While Engine Is Running Sometimes? Also Should My Engine Go Off If I Disconnect Neg, Bat. Cable While...
Asked by
jack1141
1997
FORD F-150
VIEW MORE
SPONSORED LINKS
Change Engine Oil and Filter Ferrari 458
Oil Change & Filter Replacement Toyota
Engine Oil Change and Filter Chevrolet Tahoe
Online car repair manuals
