1997 Ford F-150
35,000 MILES • V8 • 4WD • AUTOMATIC
REKOI
my truck shifts into 4wd by itself. it has happened several times. my mechanic unplugged the 4wd switch yet it still goes into 4wd
Oct 19, 2010 at 10:33 AM
  • 110,246 POSTS
Is the transfer case shifting or the front axle?
Oct 20, 2010 at 1:50 AM
REKOI
the transfer case is shifting
Oct 20, 2010 at 10:40 AM
  • 110,246 POSTS
Disconnect the actuator on the transfer case and see if it stops. You may have a short right at the plug. The switch is to send a signal to a relay then to the actuator, but power could still make it there. It could be the wiring or a bad relay.
let me know.
Oct 20, 2010 at 3:58 PM
