1996 Ford F150 Where does this wire go?
1996 FORD F-150
172,000 MILES • 6 CYL • 4WD • MANUAL
MEDIAMAN
There is a flat wire that is hooked to the passenger side firewall and is just sitting there in the engine compartment. It has a round flat terminal on the end of it that looks like it should be bolted to something - it is about 1.5 to 2 feet long. Just trying to figure out where the other end should live!
thanks!
Nov 4, 2009 at 3:35 AM
JDL
  • 16,098 POSTS
Welcome to the forum, If you don't know where it goes, can you tell where it comes from? Is the wire hot? What color/ Black is usually a ground? I can't tell for sure?
Nov 4, 2009 at 3:44 AM
MEDIAMAN
jdl123 - I call it a wire - it is almost like a flat band about 1/4 inch wide - hooked to the right passenger side firewall with a green screw. Would make me think it some sort of ground but have no idea where it goes - I just found it laying around with no apparent purpose....
Nov 9, 2009 at 12:22 AM
JDL
  • 16,098 POSTS
Yeah, flat braid, no insulation? Sounds like a ground, sorry I don't have a location for that. If the loose end is broke, you might try to find the other broken end?
Nov 9, 2009 at 12:48 AM
