HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
Vacuum Hose Diagram
1996 Ford F-150 vacum lines
MSURULES
MEMBER
1996 FORD F-150
6 CYL
2WD
AUTOMATIC
85,000 MILES
Vacum lines are not staying attatched and causing service engine light to turn on
Sunday, December 14th, 2008 AT 11:30 AM
BLACKOP555
MECHANIC
Atttached to what? You can try a mini hose clamp and snug itup so it wont fall off.
Or chances are the lines are getting old and loosing their elasticity causing them to fall off easily.
SPONSORED LINKS
Saturday, December 20th, 2008 AT 2:00 PM
Please
login
or
register
to post a reply.
Related Vacuum Hose Diagram Content
I Cannot Find The End Of A Vacuum-hose Routing
Please Help Me. Give Me A Vacuum Hoses Routing Picture For My Truck Xl, 4.2l Gasoline Engine. I Greatly Appreciate Your Previous Advice.
Asked by
Dumo Jack
3 IMAGES
1998
FORD F-150
Vacuum Lines Diagram
1975 Truck With 99,000 Miles, Engine Size 360. I Need To Find The Diagram For The Vacuum Lines. They Were Removed By The Previous Owner. I...
Asked by
revjim
FORD F-150
Vacuum Line
Truck Wont Move When Put Into Gear. It Looks Like A Vacuum Line Has Come Off. The Line Is Located Near The B.T.S.I.
Asked by
Vincent R Rapolla
1 ANSWER
1 IMAGE
2006
FORD F-150
2001 Ford F-150 Vacume Hose
Changed Out Heater Coil The Other Day And Now It Starts Up But Cuts Off Immediately Unless My Foot Is On The Gas And Runs Real Rough. Also...
Asked by
Ziggy67
2001
FORD F-150
2004 F150 Makes Noise In 2wd
My Truck Makes A Ratcheting Sound When Accelerating In 2wd. I Put It Into 4wd, It Stops. I Am Aware Of Iwe And Solenoid Issues. However...
Asked by
shffr0716
2004
FORD F-150
VIEW MORE
SPONSORED LINKS
Misfire Random Code P0300
Vacuum Leak Test and Repair
Vacuum Leak
Online car repair manuals
