1996 Ford F150 put the 300 6cly in a 1994 f-150
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
BARONMASSIE
i have a 1996 f-150 with a 300 6cly and i want to put the motor in a 1994 f-150 that has a 302 in it that is no good is there any big cost in doing that
Mar 18, 2010 at 8:14 AM
  • 110,246 POSTS
We always recommend staying with direct replacement parts because when you change like you are suggesting, there always seems to be many problems. In this case, everything will need changed. For example, you will need different motor mounts, vacuum hoses, wiring harnes, computer... I'm not 100% sure the trans will bolt to the 6cyl.
I would recommend replacing it with another 302. IT will save money and a lot of headachs.
Mar 20, 2010 at 5:14 PM
