1996 Ford F150 How to replace Clutch
FUZZYFUBU00
  • 9 POSTS
First, how do you when your clutch is going bad/out. Second - how do you replace clutch
Jan 29, 2009 at 6:23 AM
  • 31,937 POSTS
HI there,
Some of the signs of clutch wear can be shudder when taking off in 1st gear, hard gear changing, clashing in reverse, slipping under load, and drive taking up when the pedal is well off the floor. You need to remove the transmission to access the clutch, the fly wheel should also be removed and refaced, as yours is a 4X4 this is a very heavy and difficult transmission to remove at the best of times even with the correct equipment, so i would go get a quote first as if you don't have the correct lifting equipment you wont be able to do this very heavy job.
Mark (mhpautos)
Mar 23, 2021 at 7:46 AM
