1996 Ford F150 Fuel pump
125,000 MILES • V8 • 4WD • AUTOMATIC
COWGIRLUP974
I am trying to find out how you till a fule pump is not working. You can not hear it turn on when you trun the key on. When you try to strat the truck it wont trun over. We have looked for the intrunal turn off swich but we can not find it. We need help.
Nov 14, 2008 at 4:57 PM
  • 75,988 POSTS
The inertia fuel cut off switch is located behind the right kick panel
Nov 14, 2008 at 5:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
[quote:1d15f5366c="cowgirlup974"]Electrical problem
1996 Ford F150 V8 Four Wheel Drive Automatic 125000 miles
I am trying to find out how you till a fule pump is not working. You can not hear it turn on when you trun the key on. When you try to strat the truck it wont trun over. We have looked for the intrunal turn off swich but we can not find it. We need help.[/quote:1d15f5366c]
Also check the relay. Relay number 2 in your power distribution box in your engine compartment. Swap it out with another relay that is same size. If this enables the pump to turn on, you just need to replace the fuel pump relay.
Hope this helped.
Nov 14, 2008 at 5:16 PM
