Also check the relay. Relay number 2 in your power distribution box in your engine compartment. Swap it out with another relay that is same size. If this enables the pump to turn on, you just need to replace the fuel pump relay.
Hope this helped.
SPONSORED LINKS
Saturday, November 15th, 2008 AT 1:16 AM
