1996 Ford F-150 fuel system
NHEMPHILL
  • 1996 FORD F-150
1996 Ford F150 6 cyl Four Wheel Drive Manual
I am not sure if my problem is with the fuel system or not. I have replaced the fuel pump and filter. After doing so I cranked on the engine and it fired and ran for about thirty seconds and now I have nothing. I would appreciate any suggestions as to what my problem might be. Thanks.
Thursday, August 27th, 2009 AT 8:50 PM
When you turn key to run do you hear the fuel pump come on if so check the fuel pressure whether its new or old, if not check the fuel pump relay and inertia switch
Thursday, August 27th, 2009 AT 9:00 PM
NHEMPHILL
  • 5 POSTS
Yes the fuel pump comes on, I have good pressure. I bought the vehicle at an auction so I do not have an owners manual. Could you tell me the location of the innertia switch and the relay.
Thursday, August 27th, 2009 AT 10:20 PM
The fuel pump relay is located in the engine compartment fuse and relay block and inertia switch is behind right kick panel
Friday, August 28th, 2009 AT 1:32 PM
NHEMPHILL
  • 5 POSTS
Could my problem be the fuel pressure regulator? I have power to the pump and the inertia switch hasn't been tripped.
Monday, August 31st, 2009 AT 11:00 PM
Check if you're getting fuel in the cylinders. If you got good pressure that means the regulator is good too
Monday, August 31st, 2009 AT 11:40 PM
