1996 Ford F150 Freeze Plug
1996 FORD F-150
RMAGEE77
1996 Ford F150 172,000 is leaking antifreeze from rear of engine--have been told that it is a bad freeze plug--how do i replace this part without taking it to a mechanic?
thanks
Jan 6, 2007 at 8:05 AM
TAURUSWHEEL
  • 718 POSTS
You can most likely knock it out with a screwdriver and a mallet, and tap a new one in with a mallet, that is if it's easily accessible,,, some require that various parts and pieces be removed or at least removed to the side..
Jan 6, 2007 at 8:43 AM
PASSTHEBENGAY
For a 1994 F 150 6 cyl pick up w/ 100,000 mi--
if the radiator has ben repaired by a mechanic should this go bad after about 2 months? Anit freeze is leaking & logic to me says if the radiator was repaired properly this wouldn't happen. I don't have $$ to throw away!!
Thank you!
Jan 30, 2007 at 12:46 PM
